My Avail's charging port is broken. What other ways can I use to charge it? Is there a compatible wireless charging mat? Is there a charging dock that doesn't use the port? Is there a battery charging device which I can put the battery into by itself?
Charge via USB (I know yours is broken, just saying...) and a 2nd battery at the same time! You should be able to get this and a 2nd battery for under $13 or so total if you don't mind the wait from China. I might get one in case my port goes tits up. Seems to be common with these ZTE devices...
