Alternative keyboards
Dr4ke
I recently bought an Xperia Z1 and my partner a Samsung Galaxy S4. I absolutely love my Z1 (previous iPhone user) but one thing that would make it better is the S4 keyboard; something so simple to have the numbers on their own row. My Z1 has Swype, which is excellent, I just want to change the layout more than I can do on the Z1's settings..
Is this possible?
Unfortunately, Swype can't be configured for a number key row, AFAIK.
I did find some keyboards that can be set up like that on the Play Store. I'm not sure if they all support gesture typing, if that's important to you.
Kii supports gesture typing and can be configured with a number row with a premium key.
TSwipe
A.I type keyboard
dodal keyboard
As a recovering perfectionist (with little chance of recovery :)) a good keyboard is especially important for all the email and research I do. After trying many, I keep going back to SWYPE, with SwiftKey my second fav.
Both with pros and cons, it's the lightning speed I get with SWYPE that keeps me coming back.
Thanks both - apologies for delay, for some reason I didn't get a notification telling me about responses.
Swype must be configurable because the s4 has it ?
Is it the real swype or Samsungs implementation of it?
Try it from here: https://play.google.com/store/apps/details?id=com.nuance.swype.trial
Do you want the numbers on their own row, or the top row so when you hold down the key, you get the option to type the number? The Z1 can do the latter.
Samsung Galaxy Series since the S, have all come with geniune SWYPE.
However it's not always the latest version. In that event, simply go to the Play store and download the latest rev since it won't show as an update on the device until you install the Play Store Version. It overwrites the OEM version. Once that's done your set for the long haul.
Hope this helps. Oh... and yes I AM a SWYPE addict :D
Have a missed something? I can't use the hackers keyboard with my Z1 version of swype (I'm not sure what the Sony equivalent is called?). I really like this so I don't want a keyboard that cant work with it :( is it not possible?
You can't use it in tandem with the stock Z1 KB, you use it instead of.
You need to enable it in Settings -> Language & Input. Once you've done that start a text message or something that brings up the keyboard, then pull down the notification pane at the top of the page and hit Choose Input Method. Select Hackers Keyboard and you're set!
Not sure if it offers swype, but you definitely get a row of numbers at the top of the screen.
Conversely for my use, when I get an idea for some code for one of my software projects, instead of having to get out my laptop, I can switch from SWYPE to this highly useful hackers keyboard and create the code fast and easy. Try that on an iPhone ha...ha...ha...
My mind is overflowing with ideas of all the terrific things I can do, now that I'm using Android!
Just downloaded the Hackers keyboard; I like it so far.
For others (newbies like me??) who might be puzzled, in order to get the number row, you have to hold your phone in landscape mode; in portrait mode, you still have to choose between letter input and number input.
Thank you for the link, El Presidente!
Holly
If you hold the numbers key a bit longer, Swype will pop up a number pad similar to old adding machine (like right side of a computer keyboard that has number keypad)
