Up front: I know... I know there are trillion sites with the best calendar apps... and so on.
Right now, on my Samsung Galaxy S10 I use the Samsung Calendar app. and Outlook on exchange basis.
Regretfully it stops synchronising, even though all settings are perfectly okay and manual sync does not work.
I am seeking another app, that does :
a. sync with Outlook
b. easy search for events a llllong time ago (events of 50 years ago, even 60)
In the Samsung Calendar app - to search for old events - I often need to tap on bar that says
"Show events before ... date", I need to tap 40-50-60 times.
Now.. the following is important...
when I launch Edge or Chrome on smartphone and :
- long in on Google search
- go to the nine-dots at the top of the Google Search page
- select Calendar there
- then tap on 'Desktop' at the bottom (view Mobile|Desktop)
- set to 'list view'
of course everything is displayed in a tiny font, almost unreadable
- increase size a bit and flip the smartphone 90 degr, so the text is more 'readable'
- tap on the 'search/magnifier' button left of the date
- enter a keyword of whatever old calendar entry
and it will show up in a split second.
That is really great!
Except then that AFAIK this is not possible within neither the Google Calendar app normal view (no search button)and certainly not with the Samsung Calendar app.
Big question: are there any Android apps around that can do this?
Thanks!
Thanks!
