Alternatives to Existing Widgets
RJT185
For those of you who have gone outside of the pre-installed options, what are you favorite sources for Widgets?
Share with the rest of us! :)
I use Beautiful widgets for my home screen as well as calwidget for my calendar. I also use BattStat for text display of my battery level
+1 Beautiful Widgets - for the Beautiful Home Weather Widget (clock and weather).
WifiWidget
Launcher Pro Plus widgets (Bookmarks, People, Calendar, Facebook, etc.)
Pretty cool..has agenda and Month view, you can switch between the two views with a tap. Haven't had any issues with it. Scrolls smoothly.
The only thing I'd like to change is to increase the font used in it, it's just a little smaller than I'd like.
Used to be when I used ATK before reading all about how Froyo renders it useless, if you ran ATK your pre-installed widgets would "freeze" so if you ran it at 4:30pm your clock would read that until you restarted the widget. So I stopped using task killers, but now I want to see about also using non-preinstalled widgets.
Thanks for the input folks!!!
