am i having battery trouble?
rumblee1
for the past couple of weeks, iv'e noticed that my note 8 battery is taking much longer to charge. It also discharges while i use it even while being plugged in. that never happened before. any thoughts wpuld be appreciated.
Hi, have you tried removing the battery for 5-10 minutes and then reinserting it?
Unfortunately Samsung opted to put a non-removable battery in this model.
Are you still using the original charger and cable that came with your Note? It sounds like you're using a lower capacity power adapter.
True but it can't come completely off?
http://androidforums.com/threads/sa...-repair-guide-take-apart-instructions.733794/
Yes it can be removed but it's not a task to be taken lightly since it's not a matter of just popping the back off and loosening some screws, there are those nasty adhesives involved. Some people say just use a hair dryer but that will result in heating up the entire phone since it's not as focused as a heat gun where the heat is more focused.
