jarhead127
Have an LG34C, didn't see it listed anywhere else.
Hello and welcome @jarhead127 !!!
Just to be sure, you have the LG Optimus Fuel LG34c?
What carrier do you have?
I didn't see a forum for your device either, but don't let that be a hinderance, as we can try to help you
I'll move this to another forum shortly where more folks can see it and help.
Anyway, what can we help you with?
all right, cool!Yes, it's the Optimus Fuel. My carrier is Tracfone which uses Verizon in this area.
Yeah, no. j/k...
The problem that you're running into is common with lower end phones. This one has, according to the specs, 1.79 gb total internal memory which must accommodate the system, recovery and user storage. You will run out of space very quickly. Removing some apps and clearing caches and limiting message storage will be helpful, but I'm afraid you'll be at this constantly is you want to try more apps -- especially those with higher functionality. SD cards are really only for media storage. Even if you try the the workarounds to move apps to SD, it only moves part of the app and you still need enough free internal memory to install it before it can be moved (if it can be moved at all). Plus, apps running from SD will degrade performance and possibly shorten the life of the SD card.
To make this phone more useable, you will have to root it and install a custom rom with a minimal footprint. I don't know what the development community has available for this model and it's really only a partial solution. It takes a bit of research and will (theoretically) void your warranty. I wish I had better news for you but there's only so much you can do with a device that has limited resources.
Thanx for the help!
