Help Am i in the right place
dkghos
Guys I am in India and just bought a MotoRAZR XT910.....i didnt find my mobile model listed in the forum, so i selected the closest which is Moto RAZR DROID........am i in the right place or there is a separate forum for it......pardon my ignorance....i am new:confused:
depending on what your questions are for your device you will probably find what you need in here. The two devices should have a lot of similarities
Guys i am having Motorola razr xt910... just got ics update this month.. but what i am facing is that my phone gets hang once a day.. i need to force restart it (pressing power + volume)... what cud be the reason for the same....
i updated the cell by myself.. re-updating by the official moto center would help?
one more thing i am facing prob with my razr`s charger pin.. means some of the mini usb cables doesnt fit tight in it.....
Did you do. Factory reset after upgrading? I'd you are having problems with ICS then I would suggest trying that. You will lose all your data on your phone but it should fix whatever issues you are having.
Did you do a Factory reset after upgrading? If you are having problems with ICS then I would suggest trying that. You will lose all your data on your phone but it should fix whatever issues you are having.
Except for the cable. :p
If it's fairly new there shouldn't be too much to re-setup after the factory reset.
