Help Amlogic s805 .script.bin
Help what am I doing wrong amlogic s805 coding
I am new to Linux and new to these forums so hello
I have an amlogic s805 tv box make and model excelvan m400 running rooted 4.4.2 firmware exact firmware downloaded fromchinagadgets.com and can link to if needed running generic 4 wire resistive usb touchscreen and usb android touch controller showing as zd touch controller .
The issue is that the y axis on the touch screen is inverted ie up is down and vice versa all idc files in place and acts like a touchscreen .
But after weeks of searching different attempts to change this I have failed
I have adb only via wifi as unfortunately the android has only one usb port and it is a normal A type port and thus many attempts have been made to attach to pc with no joy
I can adb via wifi to the root of the device
I am looking for the script.bin file to change the screen parameters but to this date I have been unable to locate it
Here's what I've done
To pull script file from band
Adb shell
Mkdir /sdcard/nanda
Mount -t /dev/block/nanda /sdcard/nanda
The response I get is
Usage: mount [-r] [-W] [-0 options] [-t type] Device directory
Does the above mean it's mounted that directory or not ?
My next cOmand is exit
Then
Adb pull /Sdcard/nanda/script.bin
And I get the error Sdcard/nanda/script.bin does not exist
So In question
Is it mounted
Is there a file in that folder called script.bin
If not can I search for it
If not where can I change the parenteral for the usb touchscreen
Thanks lew
