An almost unusable Lenovo K3 Note
My Lenovo K3 Note had no issues before. That's what every good smartphone has. But it is came to the point where the K3 Note is almostly functional.
Here's the things that happens to me every time:
  • Google Keyboard quitting itself (even when not typing)
  • Play Music stops the music too soon
  • DU Battery Saver almostly slows down the whole phone
  • Google+ unresponded when attempting to reshare or create a new post
If you had any of these problems before and know how to fix them, let me know.
DU(Baidu) Battery Waster more like...
That's quite likely the culprit. causing the apps to quit, music to stop, being unresponsive etc. Truth is you don't need snake-oil task killers like that, also it's more than likely spying on you, phoning home your personal data to Beijing in the background. If you uninstall DU, and give it a restart, quite possibly your phone will be OK again.
I tried to do that and it's working fine. Now I realize that their Smart Charging thing does slows down my phone. However, there's other stuff unfixed:
  • Google+ not responding when posting/sharing (will not always work even when the data & cache cleared)
Almostly sounds like you may have to factory reset the device to fix the issues
Yeh, snake-oil crapware/spyware like that is often detrimental to how a phone or tablet performs. More info here....
https://androidforums.com/threads/p...k-killers-ram-optimizers-and-the-like.896663/
Can't really help with G+, I never used it.
Factory reset? I am afraid that I will lost my beloved stuff including my virtual kitten (Links from Office 98/99), GTA SA Mobile and all my songs.
Think you really should see about making a backup, and see about possibilities of saving and restoring all your stuff, just in case your phone does take a dump, etc.
