An app to tell when I'm using data?
radiocycle
Hey All,
I signed up for RedPocket and I had the $30 plan with 100MB of data. Well it seemed like I didn't even do any web surfing or use data hardly at all and all of a sudden they tell me I'm out of data.
So I've just switched to T-Mo. Anyway, I know I could just shut off the mobile data and then turn it back on whenever I want to use it, but I was hoping there might be an app that would tell me when a program is accessing the web, or using data in the background. Anyone know of some 'watch-dog' type app that will clue me whenever the phone is burning up data??
Tnx for any replies!
radio
Just turn off your data when you don't need it. it's the best way to save money and battery. My phone has Android 4.1.2 that has Data graph and I can see how much data I've used and when.
Yeah, I know I can just turn off the data but I figured it'd be cool to know which app was the sneaky data hog. I see there are a big bunch of 'watchdog' apps; I just have to pick out the one that gives the info I'm looking for. I'm running 4.4.2 so I hve that graph as well. Also I don't want to hve to turn on and off the mobile data every time I leave or enter a wifi... just lazy I guess.
radio
I thought you said you need an app to know how much data you're using not which app is using the data. Never mind.
Tmobile have an app that show how much voice, text & data you are using. You have to download it, unless you got the phone from them. At least I had to download it.
Yeah thanks, I just found that on GP earlier this evening. Won't point to which apps but good info.
r
