whoshotjr2006
Hey everyone,
I need someone who extensively uses NFC to pull some logcats and dmesgs for me.
Prerequisites:
-You have an nfc tag you can use to test with, multiple from different vendors would be ideal but ill take what I can get.
-You know how to pull a logcat and dmesg from your phone while problems with NFC are happening
-You use NFC for more than just android beam that is already working
-If you use wallet or some form of nfc payment, make sure you look through your logcat first before posting it so you dont post something you dont want others having.
I dont care which custom rom you use, but for now it will have to be a kitkat based one since CM12.1 has no nfc at all yet. I need logcats from the problems that are happening with NFC or I cannot fix it. Also please post the steps you took to run into problems so that I could possibly replicate them if needed.
If anyone can fit the above bill please get logcats/dmesgs of the problems and post them here. The more you guys can help me the more NFC gets fixed.
Thanks!
Prerequisites:
Thanks!
