No unfortunately.Does this help? Change your clock's display - Android Help
Should be noted that when you view the Permissions this app uses and how it may involve sharing in its Data Safety rating, before you install any app it's a good practice to always peruse through its Playstore page privacy statements first. I'd suggest to instead try the Simple Clock app from Simple Mobile Tools for a highly configurable, third-party clock:maybe this:
Lock Screen Clock Widget App - Apps on Google Play
Get Lock Screen clock with the collection of digital clock and time clock alarm.play.google.com
Do you actually need an always visible time with seconds displayed for some reason? This may be a less useful stopgap but the default Clock app is likely to have Timer and Stopwatch functionality in the upper or lower menu bar of the app that both involve seconds.I just got a Pixel 6 running Android 13. What app can I use to have the lock screen clock include seconds. I do not want AOD or a different wall paper.
I downloaded Power Shade and that has the ability to show the seconds on the status bar when you pull down. But it isn't on the lock screen. I got the free version first and the system shade was pulling down behind the Power Shade. But then I went to see how much the premium version cost and they had discounted it from $9.99 to $1.99. Since having the paid version the system shade does not pull down at the same time.Useless app which just shows a big clock in the middle of the home screen while the Android clock is also shown on the status bar.
Is there anybody who knows how to display seconds in the clock on the status bar?
'System UI tuner' is disabled by default in Android 13 on my Samsung Galaxy S22 ultra.
Sounds like you did all the research you needed to make your decision. If you don't want the app then don't get it. But I have yet to find a better answer to my problem. So, "let's" just reply with helpful comments.Thanks for your tip. Power Shade costs by starting the app €9.99 pro year.
The free limited version shows lots of 18+ ads 🤔
After declining the paid version a screen pops up "Limited time offer - lifetime premium €1.99"
I'm still doubtful because this app requires permission to "make and manage phone calls". Without this permission the app doesn't run.
The reviews are quite positive but we all know that everybody can leave reviews including the makers of the app.
So, let's do some research first before using a cheap app which requires permission to make and manage phone calls.
Which option specifically are you talking about?Sadly, this option does not seem to run on android 13....
