Root Android 2.1 on T-mobile (Huawei u8230) Is POSSIBLE now
DaVidaz
Hello,
As I was searching Android 1.5 update to Android 2.1 I realized that it is still hard to find a good one.. So I remade one for this phone, It gots almoust no crashes and error reports, it's almoust like the original one :)
If you need some help by updating your device you can contact me:
Deivis221@gmail.com
Deividas.Gedvilas@yahoo.com
or skype: t.gedvilas
I can send you the boot and instructions how to update, and i can even help if you can't do it with instructions :)
Bye..
I used google chrome to open that link it ask if i wanted to translate and i see it all in english now. i want to upgrade to froyo see if it works better.
Android 2.2 is very good because you can install any program to SD, Froyo is useful for Huawei mobiles because it uses low memory.. You get much faster mobile. This weak I'll try to upgrade my T-mobile.
i just upgraded my 8230 to froyo by cyanogen and it realy has improved it the software isnt as lagy when using the keybord now i wont have to get another phone too soon i can give people time to tell me whats good :)
But that soft is mada for Huawei 8220... and how do you instaled? no problems? working good?
Yep it does say pulse but i have running and its working fine my bluetooth is pairing with my navigater phone /internet are fine the phone does now think it is a pulse u8220 but i think the u8230 is a pulse with a diffrent look (i may be wrong though).
