Help Android 2.2 build not syncing contacts with Facebook
mileycasc
Hey,
I am booting an Android 2.3 build on Samsung Nexus s. Whenever I login to Facebook, I no longer get the option to sync contacts. I'm curious as to whether this is a problem I'm having exclusively, or if it's something other people are running into too, and if anyone has found a way to make it work.
Options to sync don't exist at all for me. When I go to settings in the Facebook app it normally would show a menu option for syncing, but on 2.3 I get no option. And when I go to the Accounts menu selection in system settings, I can select Facebook as an account to add but I get bounced back to the accounts list without being able to actually add an account.
Operating system =: Android 2.3 build
Cheers !
Your Sincerely,
Sahib *****
P.S : Actually I Wrote 2.2 its 2.3
Try using friendcaster instead. Facebook and Google are having a row over user data or something like that. Point is google or facebook disabled contact sync from the facebook app, but you can still do it via friendcaster.
