mudrock1000
Ok so...FroYo has been officially released. However, people are still having the same problems on the standard rom and with no fix. The only thing that should draw you to FroYo is the flash player on the browser, because ADW launcher does the job just fine. However the choice is yours to downgrade and I will leave all existing problems up for the latest build. I will update when Cyanogen gets his build up and running. Cheers and I will do my best to continue to monitor this and list fixes I can think of or anything else.
Possible fixes will be listed in red
*Known Issues*
-Battery life is fail.
-3g connection sucks
-Devs still have not made the apps able to be installed on the SD card.
-Flash does not work on some websites (Surprise?)
Wifi and Mobile network functions sometimes fail to start or connect. A possible (I mean VERY possible I'm just giving my own idea here) is reflashing the rom, or resetting up the APNs. I'm not sure how well this will work, but if you are absolutely desperate and can't live without FroYo this may be your best bet.
http://androidforums.com/support-troubleshooting-nexus/85776-problems-2-2-old-thread.html This is the old post, there are a few issues discussed in here, though please do not post in the old one.
"I want the old rom back!" Well to each his own. 10/May ERD79 -> EPF21B - Stock ROM for Nexus One images / zip / online kitchen (optional root / insecure / himem) - Android @ MoDaCo
that contains the stock rom images if I am not mistaken. Go download the lasted Eclair build and ull be good.
I'll also repost this if there are still many confusions in the official release of 2.2. Don't like the issues? Well go get cyanogenmod. Same thing, just requires root, and much better.
*Known Issues*
. Push comes to shove just downgrade back to 2.1 .
