Welcome to the forum.
Just do a factory reset on your phone. It's a known issue.
I believe that from his post it states he already done a factory reset
I can't help you with all your issues , but from what I noticed is that in the contacts , if you don't have any contact with a certain letter , it shows as a dot
There's a "little" bug with Contacts in 2.1, no groups. Is that fixed? Seeing all your groups with nothing in them is a bug and should be easy to fix. Another device (HTC) on my google account shows working groups so it is a Samsung bug. While they are free to make all those proprietary apps that I don't want what I do expect is that the google apps work as designed. If simple things written by google such as contacts and calendar don't work on this phone much less the 2.2 update then it is a serious problem.
