ANDROID 2.3 TABLET, no drivers, not compatible
Hi
Newbie here! Just wondering if anyone has advice regarding a new tablet I bought.
It's S5PV210A8, and all I wanted to use it for was iPlayer and video files, but when I received it and set up the wireless, iPlayer wouldn't play content, and my laptop couldn't find the device (says I needed drivers, which I then couldn't find online), which I needed to transfer my files to the micro sd card.
I tried a few things and then reset factory settings, and now there's not even Flash on the system. When I go to the Market, it says my tablet, which is 2.3.1, isn't compatible with Flash 11 (I couldn't find Flash 10.1). And I still can't find drivers (although I've since learned that I can transfer the files through a micro sd card adapter, so short term it's not a problem) and at some point I might need them (photo download and stuff).
Any advice would be greatly appreciated.
Thanks
Chris
It's a China tablet...
One of these?
Samsung S5PV210A8 1.2GHZ Android 2.3 7inch tablet PC-7Inch Tablet PC-MID&Tablet PC-Shenzhen Flyusb Technology Co., Ltd. China professional usb drive manufacturer & supplier
18# Donglian Industrial Park, Block 23,
Bao'an District,
Shenzhen, China
Tel: +86 755 36841932
Email: flyusb@gmail.com
Good luck. :)
EDIT:
Problem with many of these China devices, is that they often have buggy firmware with no updates or support available.
