Android 4.0.3 Help.
I want to know how to put my Apps on my Mini SDHC card. I went to Apps and it doesn't have the option to move the apps. And Apps2SD does not work. Help?
Go to apps, then on SD card. Tap the check box by the app you wish to move. Tap move to SD on the details screen. Note this doesn't work for all apps.
