Android 4.2 screenlock suck
Hello all,
Version 4.1 had a screenlock that allowed me to insert 5 custom shortcuts at the bottom.
The 4.2 version is more customizable, where you can add widgets, but it became much less convenient. It is not possible to insert custom shortcuts anymore, so I use the FAVORITE APPS widget.
So 1. I need to swipe right 2. choose an app 3. swipe again to open it. That's three actions vs. one like it used to be in version 4.1
It is possible to replace the homepage of the screenlock, but I didn't manage to find a widget that would just allow me to add my shortcuts.
Am I missing something?
Or can someone recommend another screenlock/widget for screenlock?
Ideally besides the shortcut to apps, it would also show me unread message from Whatsapp, SMS and some other info and would allow me to add shortcuts to contacts
Thanks.
Hello all,
Thanks.
You can try widgetlocker
https://play.google.com/store/apps/...sImNvbS50ZXNsYWNvaWxzdy53aWRnZXRsb2NrZXIiXQ..
