Android 5.0??
Does anyone know if and when android 5.0 will be fully released? I have been looking around, but have found nothing out but that my device will get it.
You can reduce the pain level if you plan to do a periodic update. Every major update (like 4.4.4 to 5.0.n) should be immediately followed by a Factory Data Reset. Nova Launcher Prime allows you to save your settings and restore them, after a Factory Data Reset. Tasker allows you to do the same thing.
So ... transition to using Nova Launcher Prime and Tasker and when it comes time to do the upgrade/Factory Data Reset it is a little unpleasant but not a very big deal.
(This of course assumes you are not into gaming using games that don't allow backup/restore of your progress.)
... Thom
