Hi guys, I recently got a new phone and it runs on Android 5.1. All these new look and UI is very new to me since I'm already used to 4.4 and older versions of Android. Anyhow, I'm somewhat getting used to it but there are still a few questions on my mind and this is where I need your help.
1. First of all, when I try sending an SMS to multiple contacts at once, the sending fails and I get the warning "Cellular data is turned off. Check your settings." Doesn't happen when I send to a single contact only.
2. I can't seem to view contacts stored on both my SIMs 1 & 2. I can import them to my phone and Google account though. The "Contacts to display" option only shows my Google account and neither of my 2 SIMs.
3. Why is there and exclamation point (!) on my mobile networks' signal every time I turn my mobile data off?
4. Isn't there an option to display the battery % on the task bar. Or is there but I just couldn't find it? I swear I checked every section in the settings.
5. Lastly, I still don't get how this "Adaptive brightness" works.
If you could help me or provide some links that could answer any of my questions, I would be very much thankful.
