Android 5 Lolipop
  • Start date Start date
A
Android Question
Guest
I have the original Nexus 7 tablet which I upgraded to Android 5 Lolipop this week, previously I was able to use my employers network at work which is a bit weak but usable, since the upgrade it shows an exclamation mark next to the signal icon & will not connect although if I go to settings & click on Wi-Fi it say's "Connected" but it clearly isn't. Strangely though if I tether my phones 3G it connects fine to that, I can't use that though asI only limited data so I am basically unable to use my Nexus at work now.
If there is no fix is there any way to roll back to to KitKat 4.4?
Thanks.
I'm afraid my IT dept don't know that their base from their apex but I’ve read the Lollipop upgrade has a wifi bug in it, I guess they will issue a fix in time.
