Help Android 6.0 update problems
NyGregg
I just updated a brand new S6 Edge Plus on the Net10 AT&T network to the latest 6.0 and now my MMS won't work. I wish I had never done the update and wish I could revert because it changed so much like the Themes, the Apps Edge and more
Check your APN settings. I don't know that network, but many have a separate APN for MMS in addition to the one for data. If the APN settings are wrong or got removed then you can lose the ability to send or receive MMS.
If not, what if you use a different message app?
APN is unchanged and was working before the update. I don't want & shouldn't need another message app if the Android update wasn't full of bugs.
