Hi
I bought this one: https://de.aliexpress.com/item/1005002685398006.html
I need them just when I ride my Scooter and need the Here Map and VLC for listen Music.
VLC Working perfect on my first try. Well... when it come to other Software I am not that lucky.
APKPure dont download any Software Updates but see the Mobile Website work there.
I put a Micro SD Card in and let the Phone Format them. The claim that a 128GB work and i dont try a bigger one. So In here I cant select the Micro SD Card. I try to set in the Setting put them on the Micro SD Card and the moved the Files but not see them. I want, need Download the Map Data as on my Phone.
The Kaspersky QR SCanner dont work either. It open and crash immediately. I guess the try to write something somewhere and cant so the crash?! When I am be quick and click on Settings the open and it run there until i close the settings and the crash...
I cant move the Icons? Why? Is there a way to move the Icons? I delete some unneeded stuff so there are some Icons are removed.
Thanks!
Thanks!
