Android and Cydia
Hi , dumb question as I am not up to speed with Android and Cydia/ iphone apps. Can you run a cydia app on an Android device? Or is there a way to convert or run the app within another app that would make it run on Android? thanks
Nope, it won't work. Cydia apps are no different than normal iOS apps. They can't run on Android.
There are plenty of apps in the Play Store that require root (no need for a separate store) though.
Also, welcome to the forums, Master_Dingo! :)
