Shadow Wizard
I have looked, searched, and can't come up with a straight answer.
I have seen "Yes, you can run Java apps on Android. Android is Java based"
I have seen "You need to modify the code a bit, and then it will run on android"
I have seen "You need to run a program first, and use that program to open the jar file"
I have seen a 'service' that will make your jar into an android app.
Interestingly enough, I haven't seen "No, You cannot run Java on Android"
So, whats the truth?
I have a java app I use all the time, and it would be nothing less then phenomenal to be able to use it on an android tablet. Its called maptool, and if you need to look at it, you can do so here:
hxxp://www.rptools.net/index.php?page=downloads#MapTool
So, what I am asking, is what do I need to download, who do I need to pay, or what do I need to do, to get this to run on android?
