Current Output: [[a],,[c]]
the output is like above which is i want to view from listview like:
a
b
c
here's my code at load my xml:
ArrayList<ArrayList<Object>> data = db.getAllRowsAsArrays();
String[] planets = new String[] { data.toString()};
ArrayList<String> planetList = new ArrayList<String>();
planetList.addAll( Arrays.asList(planets) );
listAdapter = new ArrayAdapter<String>(this, R.layout.simplerow, planetList);
mainListView.setAdapter( listAdapter );
here's is from my dbmanger:
private SQLiteDatabase db;
private final String DBNAME = "studentsdbNEW";
private final int DBVER = 1;
private final String TBLNAME = "students";
private final String SMYID = "myid";
private final String SMYFIRSTNAME = "myfname";
private final String SMYLASTNAME = "mylname";
my array:
public ArrayList<ArrayList<Object>> getAllRowsAsArrays()
ArrayList<ArrayList<Object>> dataArrays = new ArrayList<ArrayList<Object>>();
Cursor cursor;
try {
cursor = db.query(TBLNAME, new String[] { SMYID, SMYFIRSTNAME,
SMYLASTNAME }, null, null, null, null, null);
cursor.moveToFirst();
if (!cursor.isAfterLast()) {
do {
ArrayList<Object> dataList = new ArrayList<Object>();
dataList.add(cursor.getLong(0));
dataList.add(cursor.getString(1));
// dataList.add(cursor.getString(2));
dataArrays.add(dataList);
} while (cursor.moveToNext());
} catch (SQLException e) {
Log.e("DB Error", e.toString());
e.printStackTrace();
return dataArrays;
a
b
c
my array:
Cursor cursor;
try {
do {
return dataArrays;
