Android Applicatin consuming ASP.NET Web Service
Hi!
I'we written a simple Android java application consuming an ASP.NET web service. But it throws the error message "java.net.ConnectException: localhost/127.0.0.1:8080 - Connection refused" when doing
androidHttpTransport.call(SOAP_ACTION, envelope). Can this error be related to the Network Connections configuration in Eclipse, or any IIS configuration? Here's the code:
(By the way, IIS is runnig, I can reach http://localhost:8080/erkService.asmx and make request, get response wtih internet browser. Get message returns ony a string without taking any input parameter)
package
com.wsImpl;
import​
org.ksoap2.SoapEnvelope;
import​
org.ksoap2.serialization.SoapObject;
import​
org.ksoap2.serialization.SoapSerializationEnvelope;
import​
org.ksoap2.transport.HttpTransportSE;
import​
android.app.Activity;
import​
android.os.Bundle;
import​
android.widget.ArrayAdapter;
import​
android.widget.AutoCompleteTextView;
public​
class ErkActivity extends Activity {
privatestaticfinal String NAMESPACE = "http://artisinerji.com/";
privatestaticfinal String URL = "http://localhost:8080/erkService.asmx?wsdl";​
privatestaticfinal String SOAP_ACTION = "http://artisinerji.com/GetMessage"; ​
privatestaticfinal String METHOD_NAME = "GetMessage";​
@Override
publicvoid onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);​
setContentView(R.layout.main); ​
SoapObject request = new SoapObject(NAMESPACE, METHOD_NAME);​
SoapSerializationEnvelope envelope = new SoapSerializationEnvelope(
SoapEnvelope.VER11);
envelope.dotNet = true;
envelope.setOutputSoapObject(request);​
envelope.setAddAdornments(false);​
HttpTransportSE androidHttpTransport = ​
new HttpTransportSE(URL);
try {​
androidHttpTransport.call(SOAP_ACTION, envelope);​
SoapObject response = (SoapObject) envelope.​
bodyIn;
String result = response.toString();​
} catch (Exception e) {
e.printStackTrace();
Hi,
Thank you very much for your reply. I've changed the URL, now it is so:
http://192.168.5.68:8080/erkService.asmx. Connection is OK now, and I can even work this link in the browser of the emulator and see the web service methods. But I'm receiving another error when I run the code: "
org.xmlpull.v1.XmlPullParserException: expected: START_TAG {http://www.w3.org/2001/12/soap-envelope}Envelope (position:START_TAG <{http://schemas.xmlsoap.org/soap/envelope/}soap:Envelope>@1:207 in java.io.InputStreamReader@4052e9d0)
It cannot parse the wsdl document anyway. I didn't find any useful entry for my situation over internet but go on researching. Have you got any idea?
Hi again,
I solved the issue. I had changed "VER11" to "VER12" in creating the envelope. I rechanged it again to VER11 and now it works, I can get the response from GetMessage method. The last version of the code is below.
Thank you.
package​
com.wsImpl;
import​
import​
import​
import​
import​
import​
android.os.Bundle;
import​
import​
public​
private static final String NAMESPACE = "http://artisinerji.com";
private static final String URL = "http://192.168.5.68:8080/erkService.asmx";
private static final String SOAP_ACTION = "http://artisinerji.com/GetMessage";
private static final String METHOD_NAME = "GetMessage";
private static final String[] sampleACTV = new String[] { "android",
"iphone", "blackberry" };
@Override​
public void onCreate(Bundle savedInstanceState) {
main);
ArrayAdapter<String> arrAdapter =
new ArrayAdapter<String>(this,
android.R.layout.
simple_dropdown_item_1line, sampleACTV);
AutoCompleteTextView ACTV = (AutoCompleteTextView) findViewById(R.id.
AutoCompleteTextView01);
ACTV.setAdapter(arrAdapter);
SoapEnvelope.
VER11);
envelope.
dotNet = true;
false);
try {
bodyIn;
String result = response.getProperty(0).toString();
ACTV.setHint(
"Received :" + result);
ACTV.setHint(
"An Error Occured:" + e.getMessage());
Hi,
I am new to android, and trying to consume a dot net webservice as stated in your steps.
But I am not able to use the web service.
and when I run the application it gives error:
Sorry!
The application websertest (process com.websertest ) has stopped unexpectedly. Please try again.
please help
Thanks in advance
