Apps Android application not working in tablet
I launched android application in market and it is working fine in mobile device 2.2 and less,but not working in tablet version 3.2.
Do i need to change in android manifest file ?
U can first check in emulator create a emulator with 3.2 and check whats the issue ... otherwise it should work.... and WORK itself is a big context .. it would be helpful if you can tell the exact problem
It is working in emulator 3.2 but when i publish into market ,it is not showing in tablet version 3.2 .Do you we need any settings like android manifest file?
