I am trying to do a Popup window. But i got some errors in it. Can anyone tell me how to solve the error.
package com.example.indications;
import android.os.Bundle;
import android.app.Activity;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.widget.Toast;
public class MainActivity extends Activity {
@Override
public void onCreate(Bundle savedInstanceState)
setContentView(R.layout.activity_main);
public void onPopupBtClick (View view)
PopupMenu menu = new PopupMenu(this, view);
>inflate(error) Description Resource Path Location Type
The method inflate(int, Object) is undefined for the type Object MainActivity.java /Indications/src/com/example/indications line 22 Java Problem
menu.getMenuInflater().inflate(R.menu.activity_main,menu.getMenu());
menu.setOnMenuItemClickListener(new PopupMenu.OnMenuItemClickListener());
public boolean onMenuItemClick (MenuItem item)
Toast toast = Toast.makeText (MainActivity.this,
item.getTitle() + "was pressed",
Toast.LENGTH_SHORT);
toast.show();
return true;
@Override
toast.show();
return true;
