Apps Android application
aniga
Hi developers!
I'm creating an Android application to send commands from a smartphone to a pc via Bluetooth. I'm using Phonegap framework (which uses HTML, Javascript and CSS) to develop the app. So far, I can theoretically connect the two devices and data can be exchanged between them. But I couldn't figure out how to launch applications inside the pc and then run them remotely. I've tried to use ActiveX controls, but they are not supported by Phonegap, unlike IE which does support them. Please advise me as to the best approach to go about:
1- Launching the programs.
2- Interacting with them.
Thanks!
