Mods Android Apps Theme Engine [Root only]
Android Apps Theme Engine-- Working with Lollipop Roms
Version 4.0
A Warehouse Of Android Application Themes
Android Apps Theme Engine is the Theming tool of the future. It allows you to theme your favorite Android Apps On The Go**. It is a Xposed Module and so requires root + Xposed to work. It allows you to change the look of the app to great extent. It will not theme the framework and so all changes done are private to each app and so is much stable then a System Level Theming App.
Features:
It's main feature is to theme Android Apps.
It's Stable.
It contains Ads[Startapp Adds.][Paid Version Also Available]
Requirements:
Android Apps Theme Engine requires Xposed to be installed in your Android Device. It also requires ROOT for applying the themes On The Go** with out the need to "restart the mobile"*. It also requires an Android version 4.0+ to run.
Notes:
* You need to restart the device at least once after installing or updating to a newer version.
** To apply the theme On The Go you be need to provide superuser permissions. This simply Force Closes the App so that when you start it again the changes can reflect on the app.[/B]
Guys Please Note That After Updating To A Newer Version You Need To Restart Your Device Once For The New Mods and Themes To Work.
Requirements
• Have Xposed Framework installed
This module is not possible without:
@rovo89 for Xposed Framework, Xposed Documentation.
Me And Vishal For the themes and Module itself.
Credits : [MENTION=4939520]Shaftamle[/MENTION] For Keyboard Themes || @T3T3droid For Keyboard Theme
Currently Supported Apps For Theming:
1. WhatsApp Messenger
2. Settings
3. AOSP Keyboard
4. Google Keyboard
5. Hangouts
6. Google Play
7. Google Play Music.
8. Textra Sms.
9) Stock Message (Only supports LG Phones)
Upcoming Applications Support:
1 SwiftKey Keyboard- added for paid version
2. Stock Android Keyboard
3. Hangouts
4. Google Play
5. Google Play Music[/s]
6. Messaging Apps
Download Supports LG G2 for Stock messaging bubble themeing.
New Version 4.0 is out with a new feature to theme bubble icons of the Messaging stock app (Only LG Phones.)
Successfully working on LG G2.
We request LG users to Kindly test the new feature and leave their feedback for improvement. Other brands phones will be added shortly and made available for testing soon.
P.S- We have only made two predefined themes available in this version once adequate feedback is received clamming all working well, we will go ahead and add tones of theming options.
Installation Instruction:
The download can be made from the Opening post link or through Xposed Repo Download section by refreshing the list.
It is wise step to uninstall the old version and do a fresh install. You can also over wright the new version.
Make sure Su Access is granted and theme are set as per preference.
Activate and reboot the module.
We are planning to add language translations to the app so that user can enjoy the app usability in their preferred language.
kindly advise the desired languages.
Android Theme Engine Found compatible with Lollipop Roms.
It is currently able to theme Whatsapp, Swiftkey, Google Keyboard.
Update for Playstore and Hangouts themeing will roll out soon
Name : MultiHome/LAUNCHER Theme- Halcyon---NEW!!
No. of icons : 50+
Type : MultiHome- LgHome, Apex,Nova,Go, EverthingMe, Galaxy Launcher,Smart launcher etc
Download Link:Playstore
We are really thankful to Andrew Dayman and Cirtical_M.A.S team for icons. Also, Special thanks to @Pug123without whom this pack would have not been made.
In addition to Test build A, Please find attached the Version Test Build B which bring more features which were demanded by users from Long time back.
Whats Working for Whatsapp theme Section :
1)Whatsapp color picker theme
a)Actionbar coloring
b) Tab Indicator colour
c)Conversation Divider Line Color change
d)Conversation list text Color Change
e)Balloon Text Date color Change
f)Ballon in color pick
g)Ballon out color pick
h)Message indicator color
I)Status Text Color Change
J) Hyper Link in and Out Color Change
More to be added
Ballon in and out text color
Background wallpaper colouring
Please note; this app is only compatible with new whatapp version with lollipop material design 2,12.x.
For older version kindly use the version available in post one or repository download section.
Instructions:
Please update your whatsapp to the latest version available on Play (Adpat of Material Design lollipop Style)
Uninstall the old Android App theme Engine if you already have it
Install the test Apk from the attachment. Activate the module in Xposed Installer app
Grant Su Rights.
Open whatsapp theme section and select ColorPicker option from themes.
Set the desired Colors of your choice.
Reboot the phone.
ScreenShot:
We would love to hear your feedback for constant improvement. Do leave a liner whether or not it worked for you.
