Dear All,
I am trying a DIY home automation project. I had a Arduino + Ethernet Shield and a Andriod tablet. I would like to use my tablet to control the dimmer at home and also a ON/OFF light switch
I am beginning with Android apps building and would like to know how can I send HTTP request to a webserver host by the Arduino Ethernet Shield?
The program will read from the Edit box the IP address and then send HTTP request when a button is pressed
e.g. 192.168.1.177/?target=Z1L1status=ON
When the progress bar slide from 0 to 100%, as it slide, it will send
e.g. 192.168.1.177/?target=Z1D1status=10%
Can I know how to write the onclickListener & the onseekBarChangeListener to send the required HTTP request to the Arduino Web server. I want the Android to send the HTTP request without launching the web browser.BTW, anyone had done this with Arduino Ethernet Shield? Is this concept workable? Thanks a lot
