Android Assistant
bruce73
Has anyone else using this app had the problem of its reverting back to displaying ads after making a donation (which is supposed to get rid of them). I'm not sure when it happened, if it was after an update or not.
Edit: Turns out the problem was reinstalling the app on my new phone or possibly the update to ICS which wiped it. At any rate, the dev took care of it and the problem is solved. :-)
