Apps Android Bluetooth Serial Data Frame protocol
akagixxer
Hi all,
I was wondering if anyone knows the data frame protocol that android uses by default. Or if its dependent by phone I'm using the DroidX.
Or if anyone knows of a technical document with this information I'd be more than happy to read it for myself.
I need to know what exactly the data frame looks like, for example...
8-data bits | 1 Odd Parity bit | 2 stop bits
etc...
Im transmitting data to a microcontroller from my phone but I'm getting different values from what I am sending and I suspect it may be because the data frame the microcontroller is set to receive is different than what the bluetooth is sending.
Any help would be greatly appreciated.
Thanks!
I *think* the default profile is RFCOMM/SPP but certain devices support others such as OBEX and OPP.
As for the specific packet datagram, I'm not really sure what it looks like.
I think your question is beyond my understanding though, so I'm not sure if that is even of any help whatsoever to you heh. Sorry.
BluetoothSocket | Android Developers
I'm curious why you would work with such low level code though?
Hi all,
etc...
Thanks!
hi sir,
i am also working with android bluetooth. i want know how the frame is crating in android side. i am sending some commands to Xmega microcontroller from android side its sending the values but the controller side it receving diffrent values.
i want to know how the packet is creating in android side.
please help me..
