Android Browser for complicated webpages
  • Start date Start date
A
Android Question
Guest
Hello,
i am trying to view this website ( www_geopedia_si ) in my android browser, but it doesn't work. Problem is, when you try to zoom in this map and then move around a bit, it all falls apart.
If U will try, U will see what i mean.
This page opens and works perfectly on my PC , but it's impossible to properly view it on android. OR IS IT?
If someone has 5 minutes, please check this out , and let me know,
because it is otherwise a great map of a wonderful country and you are all dearly invited to visit!
Thanks, bye
Jan@ Slovenia
Hi and welcome
I agree a its a good map which works well on PCs (works on my linux and chromeOS machines)
I have tried 3 browsers (chrome, internet, naked browser) and all have the same result.(poor) I suspect the issue is not with the browser but with the amount of storage available for the map data. I suspect that PCs are using a large "swap" file to handle the map data whereas a phone/tablet can't do this as it does not have a hard disc or enough storage available to the browsers.
Roger
