Android Chaning Battery
dstinddr
will there be a risk or a possible problem if i change my mobile batter from
1500maH to 2000+maH or changing it to li-ion to lipolymer battery?
thanks in advance
It should be OK IF the new battery is a decent make. I've had a 2500mAh one in my Wildfire S for about a year now with no problems.
Extended Batteries are usually fine. There are typically mixed results from using them so i would suggest to read the reviews if there are some before purchasing.
Hope this helps! :)
