Help android charging
  • Thread starter Thread starter casinogpa
  • Start date Start date
C
casinogpa
Guest
when I want to charge the phone, it tells me to many apps are running and I have to turn it off to charge.
You are most likely using a charging source that doesn't deliver enough power to charge your device. While all chargers deliver ~5 volts, they differ in Amperage. Some phones will charge with the 500mA from your standard PC USB port, others require at least 2.1Amps or they will charge slowly or not at all.
What phone are you trying to charge?
