Apps android client and server side programming
mIXpRo
hi,
I'm trying to run server side and client side examples I found on the net .
Here's the server :
[HIGH]
public class ServerActivity extends Activity {
private TextView serverStatus;
private TextView serverStatus2;
// DEFAULT IP
public static String SERVERIP = "10.100.102.15";
// DESIGNATE A PORT
public static final int SERVERPORT = 8080;
private Handler handler = new Handler();
private ServerSocket serverSocket;
@Override
setContentView(R.layout.activity_server);
serverStatus = (TextView) findViewById(R.id.server_status);
serverStatus2 = (TextView) findViewById(R.id.server_status2);
SERVERIP = getLocalIpAddress();
Thread fst = new Thread(new ServerThread());
fst.start();
public class ServerThread implements Runnable {
public void run() {
try {
if (SERVERIP != null) {
handler.post(new Runnable() {
@Override
public void run() {
serverStatus
.setText("Listening on IP: " + SERVERIP);
serverSocket = new ServerSocket(SERVERPORT);
while (true) {
// LISTEN FOR INCOMING CLIENTS
Socket client = serverSocket.accept();
@Override
public void run() {
serverStatus2.setText("Connected.");
try {
BufferedReader in = new BufferedReader(
new InputStreamReader(
client.getInputStream()));
String line = null;
while ((line = in.readLine()) != null) {
Log.d("ServerActivity", line);
@Override
public void run() {
// DO WHATEVER YOU WANT TO THE FRONT END
// THIS IS WHERE YOU CAN BE CREATIVE
break;
} catch (Exception e) {
@Override
public void run() {
serverStatus
.setText("Oops. Connection interrupted. Please reconnect your phones.");
e.printStackTrace();
} else {
@Override
public void run() {
serverStatus
.setText("Couldn't detect internet connection.");
} catch (final Exception e) {
@Override
public void run() {
serverStatus.setText("Error" + e.getMessage());
// GETS THE IP ADDRESS OF YOUR PHONE'S NETWORK
private String getLocalIpAddress() {
try {
for (Enumeration<NetworkInterface> en = NetworkInterface
.getNetworkInterfaces(); en.hasMoreElements();) {
NetworkInterface intf = en.nextElement();
for (Enumeration<InetAddress> enumIpAddr = intf
.getInetAddresses(); enumIpAddr.hasMoreElements();) {
InetAddress inetAddress = enumIpAddr.nextElement();
if (!inetAddress.isLoopbackAddress()) {
return inetAddress.getHostAddress().toString();
} catch (SocketException ex) {
Log.e("ServerActivity", ex.toString());
return null;
@Override
protected void onStop() {
super.onStop();
try {
// MAKE SURE YOU CLOSE THE SOCKET UPON EXITING
serverSocket.close();
} catch (IOException e) {
[/HIGH]
And here's the client's code:
[HIGH]
public class ClientActivity extends Activity {
private EditText serverIp;
private Button connectPhones;
private String serverIpAddress = "";
private boolean connected = false;
//private Handler handler = new Handler();
@Override
setContentView(R.layout.activity_client);
serverIp = (EditText) findViewById(R.id.server_ip);
connectPhones = (Button) findViewById(R.id.connect_phones);
connectPhones.setOnClickListener(connectListener);
private OnClickListener connectListener = new OnClickListener() {
@Override
public void onClick(View v) {
if (!connected) {
serverIpAddress = serverIp.getText().toString();
if (!serverIpAddress.equals("")) {
Thread cThread = new Thread(new ClientThread());
cThread.start();
public class ClientThread implements Runnable {
public void run() {
try {
InetAddress serverAddr = InetAddress.getByName(serverIpAddress);
Log.d("ClientActivity", "C: Connecting...");
Socket socket = new Socket(serverAddr,
8080);
connected = true;
while (connected) {
try {
Log.d("ClientActivity", "C: Sending command.");
PrintWriter out = new PrintWriter(
new BufferedWriter(new OutputStreamWriter(
socket.getOutputStream())), true);
// WHERE YOU ISSUE THE COMMANDS
out.println("Hey Server!");
Log.d("ClientActivity", "C: Sent.");
Log.e("ClientActivity", "S: Error", e);
socket.close();
Log.d("ClientActivity", "C: Closed.");
Log.e("ClientActivity", "C: Error", e);
connected = false;
[/HIGH]
when running the above , the server throws and exception "Socket Closed" ,
without even reaching the while loop "while (true)".
Does anybody have an idea?
Dumb question, but you're sure you have the connection details correct? Do you have something on port 8080 at 10.100.102.15?
