Android Customized Audio Answer To Unknown Calls?
TheOneGuy
Member
I want to know if it is possible to do the following:
1. When "Unknown" calls, after a few seconds audio recording starts and asks caller to recall but with identified number this time. Otherwise there is no other way to reach recipient.
2. When not answering for a long time, audio recording starts and tells that recipient is busy.
I want to hire 2 professional voiceovers to voiceover all the above on 2 different languages.
Is this all possible?
Thanks!
Thanks!
Google Voice can do this. You can upload even an .mp3 on your computer to use as a voicemail, so your pro can record with great quality. Also, it gives the option for more than one voicemail message, depending on who is calling.
But Google Voice is not free.
