Help Android Equivalent of iPod Nano
jen2440
Member
Jun 12, 2016
83
36
Is there such a thing? I did a lot of Google searching but didn't come up with anything.
I mean the original Nano. Mine's about 1" square, has no screen or streaming capability. Size is the key here. If I remember correctly I think it cost about $40.
That's exactly what I want, but for Android, with the capability to load songs to it from my phone.
Thanks.
Upvote 0
Think the most important thing to ascertain is, does your particular phone support USB OTG? If we knew what it is, we might be able to tell you. The MP3 player will probably include a USB cable to plug it into a computer or charger. But it will need a USB OTG adapter to plug into a phone.
https://www.amazon.com/StarTech-com...&qid=1496530196&sr=1-6&keywords=usb+otg+cable
Generic MP3 players like that work as a removable drive, just like USB thumb drives.
You won't be able to use an actual iPod Nano with an Android device, because they require iTunes on a computer to load them with songs.
Upvote 0
com-5in-Micro-Host-
Adapter/dp/B00B4GGW5Q/ref=sr_1_6?s=electronics&ie=UTF8&qid=1496530196&sr=1-6&keywords=usb+otg+cable
drives.
According to my otg checker app my phone is compatible. It's an LG G3. Now I need to get the adapter.
Thanks again.
Upvote 0
BEST TECH IN 2023
Smartphones
