Android (Evo 3d) Calendar will not sync
homeispv
If I move an event on either outlook 2010 (32 bit) or Google online calendar, then use the Google Calendar Sync 0.9.4.1 program to sync between the two, the EVENT WILL NOT CHANGE ON MY ANDROID!!!!!!!!!!!!! This is aggravating and a pain in the ass as the only way to fix is to delete all calendar events (clear cache) on the android and resync. WTF?!
did you expect the changes to take effect immediately? Did you at least try to manually sync it in the settings menu?
