Help Android fingerprint recognition
Is there a way of implementing an android app for fingerprint recognition?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
    0
You would do better asking in our Application Development forum.
However, the answer will depend on which version of Android you are targeting. I believe that 6.0 has a native API for fingerprint recognition, so it should be quite straightforward for Marshmallow. It will be a lot more work for earlier versions.
Thank you much for the reply.. but I'm new to android development therefore I've no idea how to start it. I thought to do image processing for fingerprint recognition because fingerprint scanning is only available in new versions of smart phones. If u can give some ideas on this it would be a great help thanks again
You mean you want to use the camera for fingerprint recognition? It's really not my field. I could speculate, in very general terms, about approaches I might take if I were to do it, but since this isn't my field the chances are I'd miss something important, or possibly point you down completely the wrong track. I am sure that doing this all from scratch would be a lot of work though.
For any application development questions the best place to ask is here: http://androidforums.com/forums/application-development.28/
