DanceOff
DISCLAIMER: This information is intended for experienced users. It is not intended for basic users, hackers, or mobile thieves. Please do not try any of following methods if you are not familiar with mobile phones. We'll not be responsible for the use or misuse of this information, including loss of data or hardware damage. So use it at your own risk.
These are the one which definitely work:
* #1234# to check
software version of
phone.
*#12580*369# to check
software and hardware
information.
*#0228# Battery status
(ADC, RSSI reading)
*#32489# Service mode
*#7780# factory data
reset galaxy y
*2767*3855# Full
factory reset (Don't dial
it does not ask you to
confirm unless you have
problem)
These are general hence not confirmed:
So in this topic, you'll get several hidden secret codes which can be used in any Google Android mobile phone to access things which are not accessible by default.
FYI These codes have been obtained by decoding various .apk files present in the phone firmware.
*#*#4636#*#*
This code can be used to get some interesting information about your phone and battery. It shows following 4 menus on screen:
* Phone information
* Battery information
* Battery history
* Usage statistics
*#*#7780#*#*
This code can be used for a factory data reset. It'll remove following things:
* Google account settings stored in your phone
* System and application data and settings
* Downloaded applications
It'll NOT remove:
* Current system software and bundled applications
* SD card files e.g. photos, music files, etc.
PS: Once you give this code, you get a prompt screen asking you to click on "Reset phone" button. So you get a chance to cancel your operation.
*2767*3855#
Think before you give this code. This code is used for factory format. It'll remove all files and settings including the internal memory storage. It'll also reinstall the phone firmware.
PS: Once you give this code, there is no way to cancel the operation unless you remove the battery from the phone. So think twice before giving this code.
*#*#34971539#*#*
This code is used to get information about phone camera. It shows following 4 menus:
* Update camera firmware in image (Don't try this option)
* Update camera firmware in SD card
* Get camera firmware version
* Get firmware update count
WARNING: Never use the first option otherwise your phone camera will stop working and you'll need to take your phone to service center to reinstall camera firmware.
*#*#7594#*#*
This one is my favorite one. This code can be used to change the "End Call / Power" button action in your phone. Be default, if you long press the button, it shows a screen asking you to select any option from Silent mode, Airplane mode and Power off.
You can change this action using this code. You can enable direct power off on this button so you don't need to waste your time in selecting the option.
*#*#273283*255*663282*#*#*
This code opens a File copy screen where you can backup your media files e.g. Images, Sound, Video and Voice memo.
*#*#197328640#*#*
This code can be used to enter into Service mode. You can run various tests and change settings in the service mode.
WLAN, GPS and Bluetooth Test Codes:
*#*#232339#*#* OR *#*#526#*#* OR *#*#528#*#* - WLAN test (Use "Menu" button to start various tests)
*#*#232338#*#* - Shows WiFi MAC address
*#*#1472365#*#* - GPS test
*#*#1575#*#* - Another GPS test
*#*#232331#*#* - Bluetooth test
*#*#232337#*# - Shows Bluetooth device address
*#*#8255#*#*
This code can be used to launch GTalk Service Monitor.
Codes to get Firmware version information:
*#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate
*#*#1234#*#* - PDA and Phone
*#*#1111#*#* - FTA SW Version
*#*#2222#*#* - FTA HW Version
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number
Codes to launch various Factory Tests:
*#*#0283#*#* - Packet Loopback
*#*#0*#*#* - LCD test
*#*#0673#*#* OR *#*#0289#*#* - Melody test
*#*#0842#*#* - Device test (Vibration test and BackLight test)
*#*#2663#*#* - Touch screen version
*#*#2664#*#* - Touch screen test
*#*#0588#*#* - Proximity sensor test
*#*#3264#*#* - RAM version
IF YOU LIKE MY WORK, THANK ME BY THE BUTTON BELOW
* #1234# to check
software version of
phone.
information.
(ADC, RSSI reading)
reset galaxy y
*2767*3855# Full
problem)
*#*#4636#*#*
* Phone information
* Battery history
* Usage statistics
*#*#7780#*#*
It'll NOT remove:
*2767*3855#
*#*#34971539#*#*
*#*#7594#*#*
*#*#197328640#*#*
*#*#8255#*#*
