Hello Friends,
I recently rooted my Micromax A73 Phone about three weeks ago, it worked well. Installed some root access Apps such as droidApps2sd (not Simple Apps2Sd but another app that has root access), batteryuse (shows % of battery remaining) Root Browser
Here's the problem
Things that i had F**ked with my phone
1) Remove Pre-Installed Apps (Moved the apps to SDcard and delete from there) using Root Browser around two weeks ago (after that it was working fine, showed no problem)
2) Removed the Default Boot Animation bootanimation.zip file with my custom bootanimation.zip file around four days ago (though it didn't worked) but phone was worked well though showed no boot animation.
3) Changed the bootsound.mp3 around four days ago with my custom bootsound.mp3 file (working well)
Today morning my phone was showing low on space so i thought to remove some data from phone memory using root browser. Firstly browsing through the phone i came with some system font "DroidSansFallback" whose memory was around 2.1 Mb, I moved it to SD Card, phone still worked fine, after that i moved the Battery Use to Sd card using droidapps2sd. worked fine.
seems stupid but i went to pee and when i came and saw my phone it was switched off, i restarted it but it just starts up, shuts down immediately, screen remains blank. hope someone may help
*Update*:- Now it doesn't even boots. just blank screen
Here's the problem
Feeling Like A Boss
