Hey all I have looped to gather game icons which I put them into a variable that is inside an class:
In my mainActivity:
And I'm calling that back up once Glide populates that page by doing this:
But it seems to crash my app once it gets to the load(...) part. I know it has the app icon because I check it out using this:
and it came up just fine.
So what is it that I am missing in order to load these drawable variables into Glide?
LOG
Java:
public class AndroidModel {
private String name;
private String title;
private Drawable icon;
Intent androidLaunch;
public AndroidModel(String name, String title, Drawable _icon, Intent _launch) {
this.name = name;
this.title= title;
this.icon = _icon;
this.androidLaunch = _launch;
public String getName() {
return name;
public void setName(String name) {
this.name = name;
public void setTitle(String title) {
this.title = title;
public String getTitle() {
return title;
public void setIcon(Drawable icon) {
this.icon = icon;
public Drawable getIcon() {return icon;}
public void setLaunch(Drawable icon) {
this.androidLaunch = androidLaunch;
public Intent getLaunch() {return androidLaunch;}
Java:
class AppInfo {
String appname = "";
String pname = "";
Drawable icon;
String Source = "";
Intent Launching;
AppInfo newInfo = new AppInfo();
newInfo.appname = activityInfo.applicationInfo.loadLabel(getContext().getPackageManager()).toString();
newInfo.pname = activityInfo.packageName;
newInfo.Source = activityInfo.applicationInfo.sourceDir;
newInfo.Launching = pm.getLaunchIntentForPackage(activityInfo.packageName);
newInfo.icon = activityInfo.applicationInfo.loadIcon(getContext().getPackageManager());
androidList.add(
new AndroidModel(newInfo.appname, newInfo.appname, newInfo.icon, newInfo.Launching)
Java:
@SuppressLint("UseCompatLoadingForDrawables")
@Override
public void onBindViewHolder(AndroidAdapter.MyViewHolder holder, int position) {
ImageView imageView = holder.mPhotoImageView;
if (!mAndroidList.get(position).getName().isEmpty()) {
Glide.with(mContext)
.asBitmap()
.load(mAndroidList.get(position).getIcon())
.diskCacheStrategy(DiskCacheStrategy.ALL)
.skipMemoryCache(true)
.priority(Priority.HIGH)
.signature(new ObjectKey(String.valueOf(System.currentTimeMillis())))
.apply(new RequestOptions().override(150, 150))
.into(imageView);
holder.mTitle.setText(mAndroidList.get(position).getName());
LOG
2022-04-15 08:14:20.374 18885-18885/com.tutorialscache.tabslayout E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.tutorialscache.tabslayout, PID: 18885
java.lang.NullPointerException: Argument must not be null
at com.bumptech.glide.util.Preconditions.checkNotNull(Preconditions.java:29)
at com.bumptech.glide.util.Preconditions.checkNotNull(Preconditions.java:23)
at com.bumptech.glide.RequestBuilder.into(RequestBuilder.java:841)
at com.example.telluridetainment.adapter.AndroidAdapter.onBindViewHolder(AndroidAdapter.java:62)
at com.example.telluridetainment.adapter.AndroidAdapter.onBindViewHolder(AndroidAdapter.java:24)
at androidx.recyclerview.widget.RecyclerView$Adapter.onBindViewHolder(RecyclerView.java:6781)
at androidx.recyclerview.widget.RecyclerView$Adapter.bindViewHolder(RecyclerView.java:6823)
at androidx.recyclerview.widget.RecyclerView$Recycler.tryBindViewHolderByDeadline(RecyclerView.java:5752)
at androidx.recyclerview.widget.RecyclerView$Recycler.tryGetViewHolderForPositionByDeadline(RecyclerView.java:6019)
at androidx.recyclerview.widget.RecyclerView$Recycler.getViewForPosition(RecyclerView.java:5858)
at androidx.recyclerview.widget.RecyclerView$Recycler.getViewForPosition(RecyclerView.java:5854)
at androidx.recyclerview.widget.LinearLayoutManager$LayoutState.next(LinearLayoutManager.java:2230)
at androidx.recyclerview.widget.GridLayoutManager.layoutChunk(GridLayoutManager.java:557)
at androidx.recyclerview.widget.LinearLayoutManager.fill(LinearLayoutManager.java:1517)
at androidx.recyclerview.widget.LinearLayoutManager.onLayoutChildren(LinearLayoutManager.java:612)
at androidx.recyclerview.widget.GridLayoutManager.onLayoutChildren(GridLayoutManager.java:171)
at androidx.recyclerview.widget.RecyclerView.dispatchLayoutStep2(RecyclerView.java:3924)
at androidx.recyclerview.widget.RecyclerView.dispatchLayout(RecyclerView.java:3641)
at androidx.recyclerview.widget.RecyclerView.onLayout(RecyclerView.java:4194)
at android.view.View.layout(View.java:21912)
at android.view.ViewGroup.layout(ViewGroup.java:6260)
at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1829)
at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1673)
at android.widget.LinearLayout.onLayout(LinearLayout.java:1582)
at androidx.viewpager.widget.ViewPager.onLayout(ViewPager.java:1775)
at androidx.constraintlayout.widget.ConstraintLayout.onLayout(ConstraintLayout.java:1915)
at android.widget.FrameLayout.layoutChildren(FrameLayout.java:332)
at android.widget.FrameLayout.onLayout(FrameLayout.java:270)
at com.android.internal.policy.DecorView.onLayout(DecorView.java:779)
2022-04-15 08:14:20.377 18885-18885/com.tutorialscache.tabslayout E/AndroidRuntime: at android.view.ViewGroup.layout(ViewGroup.java:6260)
at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:3080)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2590)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1721)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:7598)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:966)
at android.view.Choreographer.doCallbacks(Choreographer.java:790)
at android.view.Choreographer.doFrame(Choreographer.java:725)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:951)
at android.os.Handler.handleCallback(Handler.java:883)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:214)
at android.app.ActivityThread.main(ActivityThread.java:7356)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:930)
