Android Google Map Problem
Dipali
I am getting problem in Google Map generate in my android application application can not run in emulator (bluestack) application can not run in my android phone too, i have also done debug registration using "KeyTool" menu of eclipse for getting api key and used same api key into xml "MapView" control but still i am getting following error in android phone
"Application Map Overlay Demo(process com.lightcone.mapoverlaydemo) has stopped unexpectedly.Please Try again"
i am getting following error in blue stack emulator
"Application Failure Detection. Please Try Again"
can anybody help me what should i do now ? how should i resolve this problem so that i can generate google map into my android phone and emulator please let me know if any of solution is there rather than this please let me know if i am missing some additional settings
Thank You
Hi Dipali.
Welcome to the community. Have you tried clearing data from the application?
If this doesn't fix the problem - hopefully someone with this knowledge might chime in to assist you.
Best luck. Thanks for joining. ;)
