Android Guru>Need ur help!
dorobito
when starting my android 2.3.5, the green android logo comes out then the manufacturers logo alcatel one touch appears then it stays that way... i even left it for 45mins but nothing change only the phone heats up..i even removed the sdcard, sim..but still same result...Pls help thanks:(:confused:
Is it rooted?
Do you have a backup of your system before you rooted? Did you attempt to install a custom ROM? I'm having a hard time finding stock ROMs for your phone as there isn't much info out there for it.
