Apps android:id problem
pauleee
hello, i am new to android development and eclipse ,, please assist with this simple issue cause its got me...
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:id="@+id/main_frame"
android:layout_height="match_parent"
android:orientation="vertical" >
<TextView
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:text="@string/red" />
<SeekBar
android:id="@+id/red_seekbar"
android:max="255" />
<TextView
android:text="@string/blue" />
<SeekBar
android:id="@+id/blue_seekbar"
<TextView
android:text="@string/green"
<SeekBar
android:id="@+id/green_seekbar"
</LinearLayout>
package com.example.colors;
import android.os.Bundle;
import android.app.Activity;
import android.graphics.Color;
import android.widget.LinearLayout;
import android.widget.SeekBar;
import android.widget.SeekBar.OnSeekBarChangeListener;
public class MainActivity extends Activity implements OnSeekBarChangeListener
private LinearLayout frame;
private SeekBar redSeekBar, blueSeekBar, greenSeekBar;
@Override
public void onCreate(Bundle savedInstanceState)
setContentView(R.layout.activity_main);
frame = (LinearLayout) findViewById(R.id.main_frame);
redSeekBar = (SeekBar) findViewById(R.id.red_seekbar);
blueSeekBar = (SeekBar) findViewById(R.id.blue_seekbar);
greenSeekBar = (SeekBar) findViewById(R.id.green_seekbar);
redSeekBar.setOnSeekBarChangeListener(this);
blueSeekBar.setOnSeekBarChangeListener(this);
greenSeekBar.setOnSeekBarChangeListener(this);
@Override
public void onProgressChanged(SeekBar seekBar, int progress,
boolean fromUser)
frame.setBackgroundColor(getColorFromSeekbars());
@Override
public void onStartTrackingTouch(SeekBar seekBar)
// do nothing
@Override
public void onStopTrackingTouch(SeekBar seekBar)
// do nothing
private int getColorFromSeekbars()
return Color.argb(255, redSeekBar.getProgress(),
greenSeekBar.getProgress(), blueSeekBar.getProgress());
The error is the following R.id values "cannot be resolved or is not a field."
Assistance is greatly appreciated..
Thanks Paul
Paul
In the eclipse menu , click on the project menu and click clean project. I have had this type of thing where eclipse is not auto building or cleaning the project so the code does not see the XML layout references
Thanks
TimCS
