Maybe someone can help me out with this. I'm using Android Gingerbread 2.3.5. I'm not going to name the phone because every time I do someone moves it to a forum that nobody ever goes to and I never get any replies.
So the typical AT&T phone seems to have 3 sources of storage memory. As does mine. That would be the internal phone storage, the SIMM card, and then the SD card that is user added. I'm using a 16Gb one right now. Recently the wife got a new phone and I needed to take over her old phone. Since mine was dead. So I simply swapped my SIMM card, and my SD card over into the desired phone. But for some reason, android decided not to save any of my numbers and never ask me to make a backup or anything. Its not like Windows when something new happens. Windows is like 100000 times more intuitive than android. With windows, every time you install a new storage memory device, it asks you what you want to do with it. It helps you along a bit. Or go to save a piece of data, it conveniently asks you where you would like to put this new piece of data.
This serves two purposes. It helps you remember where its at, cause you actually had to draw your attention to it, and it organizes it away for you for later use. With android, who knows? The dam files aren't even appropriately named. Android doesn't ask you any questions or give you any help at all with regards to what you want to do with your stored data. Such as phone numbers and pics taken with the camera. It just slaps them in some folder that isn't even named right so you don't even know where to find them. Ugh. So frusrtating.
And then, when you plug in a new card with new phone numbers, the stupid phone program never asks you if you want to import all your old phone numbers off the card. You're just screwed.
Hard to compare Windows OS to a phone OS. At least with Android, there's apps that can make that easier or can be improved in the future.
